Learn PLC's : Level Control
Calistodwt
May 2003
George, South Africa
187
I was trying out the SLC500 simulator and loaded the level control application from the "Learn PLC's Tutorial". In single scan mode I found that after scan 1 that all the XIC's showed as being TRUE the same as scan 2-100. Is the diagram in the tutorial wrong? If not why not?
Calistodwt,
No, best I can tell, it is correct. Remember, the two level switches are Normally Closed lying on the shelf. So before anything happens, with the oil tank empty (Scans 1 to 100), both level switches are ON.
Pump is started in Scan 2 and runs. At Scan 100, the Low Level sensor is covered and goes Open (off). Pump is sealed in by itself (self-sealing), so keeps running until High Level sensor is covered and the Pump is cut off on Scan 1001.
As mentioned in the title, I want to learn about PLC systems. Long story short: I had to strip out a plant room. Everything was going to the...
2,609
Hello Gurus, I have started teaching myself Allen Bradley PLC with RSLgoix 500 and LogixPro with grateful and helping comments of you gurus...
3,989
Hi, guys, how’s going? Our company gets new production lines with AB safety PLC. Could somebody tell us where we can find manuals, videos… to...
1,765
Hello, I am new to PLC. I am looking forward to learn about it. Any Beginner guide will be appreciated. Ebook Or online Guide. Thanks
1,437
So Basically i work for a controls company, but im in the software department (programming) and i would like to improve my self and learn how to...
3,264
