Lincoln Power Wave 455M Devicenet PLC control
dextaca
Mar 2024
Ontario
Good day Forum Members
I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M with Ethernet DeviceNet option.
I have some PLC/ HMI programming experience but nothing like this. Wondering if some good soul could point me to the right direction , on the hardware / software needed to get a basic Devicenet contoller going ?
kindly all comments inputs are appreciated.
Kindly
P.
Depending on exactly what you want to I would look at a Micro 800 series PLC or a Logix PLC
With either one you can get Device net modules
Keep in mind Device Net has reached the end of life and I would see if there is an ethernet options for the welder
I have done more than a few welder system this was before the welders has networking ability I used isolated analog outputs to control the welders
that still may be an option for you
Good morning Gary , thank you for the details , yes the welder has en Ethernet option installed, it uses Power Wave Manager for management.
Lincoln support person told me that I could used DeviceNet old school or ArcLink XT ethernet for control , problem I cannot find any info on ArcLink Xt or Arclink,, I found fragments on the IP port etc, but nothing else.
Hello
The ArcLink is a proprietary network protocol for Lincoln designed to work with their devices but if you want to connect it to a PLC then I think your better choice would be Ethernet.
If I were you I would contact Lincoln and check with them I believe you can connect Modbus over Ethernet
I may take you a little learning time but I think it would be a better option
They support Device net but as we all know Device net has reached it’s end of life at least with Rockwell while I am sure you still set it up but replacement parts are going to get harder to find. I think the last thing you would want is to get everything running and a years or so down the road and you have a problem and you have to shut everything down to redesign it because the Device net parts are unavailable
Incidentally I have a Lincoln TIG 225 myself I use for repairs and small personal projects. It’s a great machine.
Trying to integration Dozens of Lincoln Powerwave S500 welders into our I4.0 network, ultimately into Kepware. Does anyone have a proven solution...
1,764
I have a new project that uses a Lincoln PowerWave 1000 AC/DC welder and a Allen Bradley CompactLogix to control a manipulator. On all of our...
2,944
Sorry for the Off-topic question. Was driving a 2001 Lincoln LS on the Highway when the traction control started to apply the brakes slowing me...
3,718
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
195
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
51
