Link PLC5 with Siemens S7-300
gbarenbaum
Jun 2003
I need link a PLC5 (5/25 with DH, DH+ or DF1) with Simatic C7 with Profibus DP port.
With the cheapest possible way.
I think, PLC5/25 has not Ethernet capability. I'm right?
Thanks.
I have had good success and it is very easy to setup the SST Module for Profibus on a PLC5 rack. This will be the best way to do it. Again even if you had the capability of ethernet you will be doing too much code/ladder to achieve what you want. The SST method is the most reliable.......
Venkat
Today I was looking at a system where 3 PLC 5 having each about 15 nodes under ControlNet / Flex io ... All the PLC where "talking" to...
3,528
How to config ab_rapd driver in Factroylink 7.5 to communicate with PLC5/40's CH0.Thanks a lot.
1,374
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
82
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
94
