Little Star PLC
joker438
Aug 2015
Louisiana
I am working on backing up some Little Star PLC's for a customer. I am able to download to them but can't upload. Has anyone had any dealings with these and can point me in the right direction?????:mad:
Welcome to the forum!
Just when I think I have read about all the oddball brand out there...Google is no help for this one, so can you give us more information? Maybe a picture?
Little Star
I have done quite a bit of searching online. Very little info on this guy. I am able to download to it but cant upload. The Easy Start programming software it comes with doesn't really have an upload button but in the manual it says something about uploading through a modem. I also done some reading on the EEprom. The EEprom is a chip on the mother board. I am wondering if this could be copied and replicated to another chip. I have never done this before but have heard it could be done. Any help would be greatly appreciated.
Little Star
It will be. A customer of mine just purchased a sub sea well making 1200 bbls/day. This is doing some watchdog timers for A and B. Plus one running all the controls on the HPU and another one running all the controls on the Chemical Injection. We have no backup programs incase they **** out. With the price of oil they don't want to do an upgrade. Looks like they will have to.
Do you feel lucky?
ftp1.digi.com/support/documentation/0190015_f.pdf
It looks like the same unit as in your picture. Good news is that Digi bought them. Bad news is that it's a PITA to find documents on their site for obsolete stuff.
I'm not familiar with this unit at all but will try to answer what I can in a general way.
The 1st thing you need to do is get the Mfr. and part number off the EEPROM. A quick google and ebay search turned up many EEPROM programmers available. If the chip is removable and blank chips and a programmer can be obtained, burning backup copies should be easy. Most of them come with simple software for copying chips.
Most programs written in "C" type language are converted to (Assembly) machine language at compile time. I am not surprised that you can't upload from the plc since the program is running on (Assembly) machine language. The program (Assembly) code should be run thru a De-compiler program to even edit it.
From what little I read in the manual just "Data" created for or by the PLC could be Up or Downloaded thru a modem.
Little Star
The EEProm is removable. I will look into something to copy them so we can have a backup. The info online is very limited. I had called DiGi and they were not certain you could upload from the unit. Thanks for yall help.
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
228
Hi, Need a little bit guiding using SISTEMA software. As I understand a subsystem consist of components and are the same category. I'm confused...
2,646
Good morning everyone, I've got 2 servo driven axes that each use a Heidenhain glass slide to the motion controller for position and velocity...
1,408
RSLogix 500, what is the little image next to the ladder in the project tree? it looks like a little blue bug with a red dot on its back. just...
2,049
Hi everyone, trying to get data out of a digital encoder that is little endian into my Siemens S7-1200 controller that is big endian...it's an...
3,394
