Load sharing between two drives
Plc_User
Dec 2005
Belgium
317
I have two motor that are rigid coupled and drive a belt.
What is the best way to share the load between both.
A need a controlable speed for the belt.
The drives are Unidrive SP.
I know there are different principles to share the load.
Tell me your experiences with loadsharing (whatever brand it concerns).
Thanks.
The simplest method, that is often the easiest to incorporate, provided the drives can handle it:
1) Make the master drive a speed regulator, the slave drive a torque regulator.
2) Take the Torque Command output from the master drive, and feed it to the slave drive.
This assumes, of course, that you can get to the post-speed regulator torque command, and even more, that the drives can operate in a real torque mode. Many lower end AC drives cannot.
I'm with rdrast if you don't have a separate free-standing controller that can put out a torque command. I have used the velocity master/torque slave method on dual spindle unwinds and rewinds quite effectively.
But again, if you have a high bandwidth controller that can directly put out a torque command, run both drives in torque mode and run the torque command in parallel to both drives. I have seen multi-motor cut-off knives done this way.
Keith
I don't know what your speed accuracy requirements are but, if they are 1% or more error, a very simple arrangement is to power both motors in parallel from one drive.
The motors must be identical. Otherwise, rdrast's system is the best, in my view, as long as there is no reasonable chance that the follower motor can break away and run up to max speed on its own.
For a stone crusher, which is driven by 2 identical motors (each 160kw) has VFD (SCHNEIDER ATV930C22N4C) for 1st motor and 2nd motor starts DOL...
27
7,922
I have been asked to quote a few jobs lately that have conveyors with 2~4 motors running the same section. These are explosion proof motors and...
3,202
I have several long conveyor systems (6" chain) powered by multiple 7.5 HP DC motors. DC drives are AB 1370 Series B and are very old and no...
7,894
I am currently commissioning a system of DC drives that I would like to have load sharing capabilities. I am using a L63 ControlLogix controller...
5,213
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
28
