Lock desktop while RSVIEW running
rocksalt
Aug 2008
Texas
102
I have a situation where I need to lock out the desktop access while RSVIEW is running. I want the project to run without the ability to call up the task bar, CTRL-ALT-DEL, ETC from working. But... I need a backdoor... Machine is running windows 7
RSView comes with a utility called Desklock that might just be the ticket for what you want. I have not tried what you are looking for, but it replaces the Windows Explorer, and has options to disable CTRL-ALT-DEL etc.
I don't have access to RSView here, so I can't check the Options. It should be under the RSView Tools.
Stu....
Can anyone recommend a desktop lock application that would be good for industrial use? I know the FlexLock utility is shipped inside DeltaV and...
1,206
Dear Friends, we are using RSVIEW in our system with PLC 5, the problem is that we have forgotten the PASSWORD of the RSVIEW desktop lock...
2,310
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
27
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
77
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
132
