Lock desktop while RSVIEW running
rocksalt
Aug 2008
Texas
102
I have a situation where I need to lock out the desktop access while RSVIEW is running. I want the project to run without the ability to call up the task bar, CTRL-ALT-DEL, ETC from working. But... I need a backdoor... Machine is running windows 7
RSView comes with a utility called Desklock that might just be the ticket for what you want. I have not tried what you are looking for, but it replaces the Windows Explorer, and has options to disable CTRL-ALT-DEL etc.
I don't have access to RSView here, so I can't check the Options. It should be under the RSView Tools.
Stu....
Can anyone recommend a desktop lock application that would be good for industrial use? I know the FlexLock utility is shipped inside DeltaV and...
1,206
Dear Friends, we are using RSVIEW in our system with PLC 5, the problem is that we have forgotten the PASSWORD of the RSVIEW desktop lock...
2,309
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
127
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
137
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
202
