Logix 5000 For Air/Fuel Curves
Jun 2020
Pennsylvania
I am about to be upgrading several compressor engines to Logix 5000 and I am looking for the best, proven, ways to program in the various curves. I believe that this can best be accomplished using a lookup table function, but I have not personally done that before.
Any advice?
Thanks!
What is your desired accuracy?
If they are smooth, I would suggest a Chebyshev approach, converted to a polynomial.
What is the coding environment e.g. ST? Ladder?
Does it look like the plot on page 18 here: https://www.osti.gov/servlets/purl/841083? Or the plot on page 10?
Maybe a better question is, what are you measuring, and what are you controlling?
It looks very much like that curve. And the formulas contained in that paper are exactly what i am looking for.
So, we are controlling engine ignition timing according to the air/fuel curve, exhaust manifold temp curves, etc. There are around 4 curves that are used. They work on a low signal select control scheme. So, basically I am looking for any way to program a curve into the PLC and have it produce an result that can be scaled and output.
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
169
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
60
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
71
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
168
