Logix Studio Support for L63 controllers
mohsinalich
Jul 2018
Lahore
Hello I want to Use Studio5000 Logix Designer V 28 and the PLC i have it L63 Control logix controller. Are they compatible? As in the Logix Designer i dont see the option to change the controller to L63.
Regards,
Mohsin
Only compatible up to v20. You will need to change the controller or your software.
Google Rockwell Compatibility and you can check yourself.
For CompactLogix and ControlLogix controllers, your RSlogix5000 or Studio5000 version must match your controllers firmware. For example, to use Studio5000 v30, your controller must have firmware V30 installed. If you have a controller with firmware V20 installed, you must install RSLogix5000 V20.
The L6x series of processors cannot be flashed above V20. Therefore, the latest version of software you can use with your processor is RSLogix5000 V20.04. Your processor must also have firmware version 20. If you are working with an existing application that was installed on firmware v17 for example, you will need to install RSlogix5000 v17 or you can upgrade the program in RSlogix v20, flash up the processor to v20, and reload the program to the processor.
Good Morning , I have some projects in the works and I would like to start working on concepts and having meetings with animation to sell my...
33
71,163
Does anyone know why CompactLogix L4x Series are not supported with Rockwell's new Studio 5000 Software? My understanding was that RsLogix 5000...
5,553
Hi, I was wondering what the extent of the Japanese language support is for Logix (Studio) 5000? I know there is a JP version of the software...
4,095
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
141
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
291
