Brijm
I have an application we where looking at, that would use an array of UDT's created from an add on instruction. We where also looking at using a Red Lion Graphite HMI. I setup a test program, to try and address the UDT's. I'm using the Ethernet L5K file and imported the tags from my test program.
The issue I'm having, is that when using the L5k file, it appears, that I need to address the PLC directly. With this, I cannot use an index variable to step through the array on my screens.
I can address [PLC2.WorkingDP[0].plsFrom] but not [PLC2.WorkingDP[nIndex].plsFrom]
Tech support wasn't any help, and I wanted to see if anyone here has found away around this. Perhaps I'm just trying to go about things the wrong way.
