logix500 tag import to PV800
mike nz
May 2008
Auckland
I am trying to import tags from a micrologix 1400 to a PV800 in CCW.
CCW gives the option of micro800 or compactlogix 5370 in the tag editor. Not micrologix or SLC500. Is there a way to import these tags?
I am using version 12.00 of CCW
Mike
Striclty speaking, does RSLogix 500 actually have a tag database the same as 5000? I didn't think that the I/O's in 500 were contained in an...
13,075
I'm looking for a document that explains all the tags associated with the Axis_Servo_Drive tag. This is the tag that shows up in Logix5000 once...
2,228
172
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
108
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
543
