Logix5000 Task Monitor 3.4.1.0 and L85E CPU
Pete_S
Mar 2015
Portland Maine
76
Hi. I have a L85E CPU with FW 28.12. I can see the CPU in Linx but when I select it in the Logix Task Monitor v 3.4.1.0 I am not able to start the monitor. Has anyone had any luck connecting to a L85E controller with the task monitor tool, and if so can you please advise what version you are using? Thanks!
If your PC has Logix Designer v30 installed, Logix Task Monitor 3.4.x.x.x will not be functional due to .NET Framework 4.6 or newer incompatibility.
Logix 5000 Task Monitor tool v3.4 not supported with v30 of Studio 5000 Logix Designer
1009403 | Date Created: 01/06/2017 | Last Updated: 05/03/2017
Access Level: Everyone
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/1009403
What about RSLinx, NET Framework and FactoryTalk Services Platform?
RSLinx cannot be v3.90.
NET Framework cannot be 4.6.
FTSP cannot be v2.90.
Is there a way to still be able to check outgoing messages/Communication usage? The web-server seems really lackluster.
I recently installed Logix5000 v20.01 on my laptop computer, and installed the v3.0.3.0 Task Monitor along with it, after removing the old...
4,215
I have a RSLogix5000 project that I need to test for various program sizes, in order to validate its robustness. I want to introduce delay in my...
4,530
First time using an Event Task in Logix. And what I see makes no sense before I even start... Created a new Task, and under "Configuration" Type...
2,960
i created a couple of "new programs" under the Main Task that i no longer want. when i right click on their names..."Delete" is greyed out. how do...
3,769
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
