Looking for a solution for a Wireless Mobile FactoryTalk ME Tablet
sanger
Nov 2005
Toronto
172
We have an application where the system requires a wireless portable HMI for maintenance troubleshooting. Adding FT View / ViewPoint servers are overkill for this application so we are hoping there exists suitable hardware that could perhaps run FT ME directly. The portable HMI is required to only allow a subset of the functionality of the main HMI so using a VNC connection to the main HMI is not an option.
You can run an FT View ME Station runtime on a rugged portable tablet PC. You can cut down the existing HMI functions into a new application to run on these portable tablets.
These should be suitable:
http://www.panasonic.com/au/busines...ebook-tablet/fully-rugged-toughpad/fz-g1.html
http://www.advantech.net.au/products/1-2kwkn0/pws-870/mod_65eb02ba-72c6-4fab-ba32-611ad11364fc
Good suggestions. I'm sure that FactoryTalk ME is not officially supported on Windows 8/10 but has anyone tried it with any success?
Check this product out. There's versions with built in web-server. They support a bazzilion protocols and can do data-logging and write to SQL as well. There are also cellular products to compliment the base product.
Good Luck,
Yosi
Probably not the answer you are needing, but I have programmed a cheap $85 windows tablet, that natively runs AdvancedHMI wirelessly to a AB controller for troubleshooting and maintenance. It works well and the software is free.
You can remotely connect to a running ftview hmi if you compile it with viewpoint.
You just need a browser and the IP of the machine hosting the running project.
That way you dont need special hardware but you need it running somewhere else.
If you use a panelview for the main HMI, you could also enable the VNC server.
Hi All, I am in need of a way to measure a pulse that will have an approximate duration of 7msec. I would like to have a resolution of 0.5 msec...
1,788
I need to create a 120v UPS from 12v batteries and a charger/supply device that has some intelligence behind it. I have one from Sola that comes...
21
3,721
Hi all, I need to communicate to ten weigh controllers via Modbus, one address per scan. I have the logic working by using an ADD block for the...
3,151
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
271
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
163
