Looking for opinions: Ultrasonic tank fluid level sensors
I agree they all have their problems, It's just out of the 100's that I have installed I have had better luck with "submersible pressure transmitters". I think in ever application you need to know conditions your environment will/might be, and that has to be considered when it comes time to purchase your sensor.
Good Luck
Pulsed Radar also works really well. We have had good success with the VEGA VEGAPULS line. They aren't cheap, but they are bullet proof. Using the available configuration software, you can tune those babies to handle just about anything, multiple layers of material (oil/water), foam,sludge, in tank obstructions (dip tubes, agitators), etc. They can even shoot through the closed top of plastic IBC totes.
Again, all your input is appreciated. I'm not locked into Ultrasonics, and really want a sensor that will put up with the abuse of 5+ years in the oil fields. I've also been looking at Pressure transducers since I read some comments here.
Hi everyone. I'm working on the design of a semi-automated pneumatic vertical press controlled by a non-safety PLC . It’ll consist of two...
1,094
If you were building a wireless set up for PLC control, would you prefer MODBUS TCP or something like the Allen Bradley Stratix 5100 wireless AP...
2,627
I first asked about ultrasonic here http://www.plctalk.net/qanda/showthread.php?t=98132&highlight=radar I changed my mind, I want to go WGR...
2,771
hello everyone, Our mill Is looking at the possibility of upgrading our current automation system. We currently have 50 PLC's through out the...
9,525
I've got a machine builder wanting to use the AB Micro800 series for an upcoming job. I realize that from a machine builders perspective, the low...
5,602
