Looking for simple RS5000 logic for 3 axis servo
dsking
Dec 2008
ontario
66
I'm lookin for help with a simple 3 axis or even 2 axis servo logic(control logix) for making 4, 3" holes one at each corner and then a 2" x 2" square at the centre of 9" x 11" sheet. Thanks for all your input in advance.
You're asking us to do alot of assuming here bit...
It sounds like you have an X-Y gantry system above a conveyor that brings blanks into the station. You have a ControlLogix processor (which one??) with a motion card (which one??) and a couple motors and drives (which ones??). On the business end of the gantry you have a machine tool of some type that will both drill holes and scribe lines, presumably with a common tool since you didn't mention tool change.
How am I doing so far??
Keith
Keith
Thanks a lot kamenges. It is an X-Y gantry system with a conveyor below that brings in blanks and transports the products after the holes have been drilled on them. Well this is a softlogix project for now,ll use a 1756-L61 controller when i have it figured out.
I'll be using a common tool for the entire job.
Is the square in the middle orthogonal to the blank edges or can you specify different orientations? Do you need to search for the blank and it's orientation before you start or is the blank oriented already as it enters the station> Is the square a cut-out or just a scribe?
Keith
The square in the middle is indeed orthogonal. I would like to search for the blank before i start drilling. The square is a complete cut-out.
Thanks once again.
I'm working on a fairly simple project where I need the ability to display some basic fault messages. The scope of this project does not justify...
21
2,667
Looking for a simple "controller" that fits in a standard 3.77 x 3.77 (96 x 96) cut out. We have many different controllers here which will do...
3,399
In one of our locations, we have a single ALLEN BRADLEY PLC 5 which will have Ethernet capability. It controls a simple conveyor system. We are...
2,033
HEllo all, I am charged with making a demo case for a linear actutator. This will be Servo driven and interfaced to a PLC. I need to find a very...
22
7,135
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
