Hi guys,
I'm going to replace our mercury-wetted relays with Solid State relays and I'm looking for advice on what you would use.
The current setup (what I would like to replace) is:
3 pole, 40 amp, 480 volt Mercury-wetted relays, and,
2 pole, 30 amp, 480 volt Mercury-wetted relays.
Both relays are controlled off of a GE Genius output block (there will be some leakage there) running at 110 VAC.
I've looked at HB Controls (www.hbcontrols.com), and they look impressive. Any other suggestions?
As always, thanks.
As always, thanks.
