Looking for standalone cheap ETH IP I/O module
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but this is just for my curiosity and I don't want that expense. Anyone know of a small standalone EIP I/O brick, all self contained that is under a couple hundred bucks?
I have never done it. But... I understand the Automation Click series can be used as EIP remote I/O. Meets your budget requirements. You will need the Click and a power supply.
I was just there looking and got the impression that it wasn't REALLY EIP for AB PLC's... but I'll take a look again
I DK if AB does it different, but I have interfaced with CLICK Plus over EIP with Wago/Codesys using the EDS files generated in the Click software. Quite easy IMO.
That's what Ken was showing me. That's quite an option for a LOT of things and probably where I will go. I think I have a couple Clicks around here somewhere from a ModbusRTU to Analog conversion I needed to do years ago
Those aren't less than a couple hundred bucks. As soon as E I/P gets added, price goes up a lot. I'm not gon find my unicorn
Probably not, as I have never found one either.
I have looked at the Clicks and others, but by the time you do the engineering, build the enclosure, punch holes for fittings/connectors... Buy all the stuff, toss in labor, materials... It's cheaper to drop in a 1732E, or something to that effect.
I have looked at the Clicks and others, but by the time you do the engineering, build the enclosure, punch holes for fittings/connectors... It's cheaper to drop in a 1732E, or something to that effect.
This is a lot less formal than that but the click programming is a consideration. Its not hard, but just another link to debug.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
205
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
146
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
395
Good Afternoon , We all must of done this before ...... Installing a Frequency Drive in an enclosure , you forget how deep your selector...
147
