Lost connection to Encoder Siemens
Dragumer
Jun 2022
Heemstede
Good afternoon! Please help, the following situation happened:
Connected encoder Siemens 6FX2001-5QN25 with Profinet IO to PLC S7-1200.
The name was set to the encoder normally, IP also assigned, but after updating the PLC program to which I connected it, the encoder lost the connection: the Link and Active indicators went out, I can't connect to it now, neither by name, nor by IP, nor by MAC address.
How can I connect to it or reset to factory settings?
P.S.
I couldn't connect via Proneta.
Two cables for Profinet were bought with the encoder, replacing with another did not help.
The second port behaves similarly.
Status 1 – Red, Status 2 – Green.
At the Mac address now also does not connect.
The encoder is not displayed in the DeviceID.
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,049
Hi all I am working on a retrofit project. There is one backup pump with Powerflex 753 drive controlled by 2 different PLCs(one 1756-L63 ,one...
1,534
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,585
The problem below is what I am getting. Not sure of the fix. Connection lost. the connection from the alarm and event server...
803
