Lost DF1 Driver In System Comms On RSLogix 500
sharkyh2o
Dec 2013
Snow Shoe
129
I no longer have an option to select df1 path and was wondering if anyone has ran across this. I can configure in RSLinx Classic and see the PLC in RSWho. I am running windows 7 on my pc and version 10.00.00 for logix
Everything seems fine in Linx. I can delete add auto config, just no path in rs logix. First time it happened was a new 1400 plc that had no ip address so i wanted to use df1. Auto config in linx, opened the .rss file and did not have a path. Went to controller properties, Controller Communications tab, then i had a path to df1, clicked on who active, saved the program, then path was open under systems comm. Next upgrade i could not restore it with these steps? Never had to do this before and not sure why it is happening. Just tried these steps and it worked at this time. Really confused.
Driver is available after i change the programs path? I do not believe that i have ever had to do this before.
Just wondering, I have to log on to a different domain to have admin rights to my PC per IT rules instead of my company domain if that has changed the path and caused my problem?
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
82
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,124
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,049
Hello, My laptop was rebooted lost 500 & 5000 tried to re-install but need to activate, need help badly, Thanks
774
