Lost forever ?
Puzzled
Jul 2018
Auckland
Hi all
I am a newbie to the forum. I have a question about an AB compact logix L32E series A. I have the following configuration -CPU Power supply ECR endcap - no I/O connected. I performed a firmware upgrade from v15.0 to v17.01 using the flash utility using the serial port.This appeared to be successful however after recycling the power the I/O led began flashing and the ethernet module faulted. Following the revision notes for version 17 I removed the battery for 24hrs and the firmware version reverted to v1.15. I then reflashed but still no ethernet port.Inhibiting the ethernet module clears the I/O led flashing. Has the ethernet port departed to a different continuuim or is it recoverable ?
Any help appreciated
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
85
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,131
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,021
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,052
Hello, My laptop was rebooted lost 500 & 5000 tried to re-install but need to activate, need help badly, Thanks
778
