A recent post i just read about an LVDT triggered this question.
I've put these small LVDT's on cylinders to measure part length. They too had about 1.5" stroke/readable distance. I placed them on small 2" cylinders.
My part lengths varied within 1 to 35 mm.
I am curious how to calculate the actual resolution of the LVDT.
I just scaled it according to what i needed to complete my own readings.
But i had to do this on different machines some with newer PLC s some with older PLCs. Greater than 15 years old.
They are not allen bradley, siemens or mitsubishi. They are a machine control internal PLC.
But using different PLCs i did notice numbering feedback from the sensor before scaling were different.
For instance one plc went 0 - 32767 once it hit that it rolled over to a negative 32767 and counted up and back and forth.
Another plc went 0 - in the millions. (0 - 21,333,333) example.
I have them both set up to read/register the same number of bytes. (4) for this analog voltage input. 0-10v
Does this mean each version of plc read in a different format? I dont even know how to acurratly phrase the question i want to ask in programming terms.
Can anyone explain this to me?
Thanks,
Thanks,
