M340 Pc connectivity using mini USB
Summi
Nov 2009
Nagpur
hi,
i am new 2 Schneider controller i am using a M340 controller, as soon as plug in a mini USB cable in the PLC, pc says new hardware found i am unable 2 find drivers on any of diske with it.
Pls Help!!!
hi,
Pls Help!!!
If you are using Unity then it should have come with a Driver Pack disk, the installation process asks you to insert this during the install.
Hello Dears Im facing a problem in connecting to M340 CPU through mini USB , i tried many things to fix like reinstalling the usb driver again ...
3,086
Hi all, Is it possible to write the data words (%mw) of m340 plc with the values present in database (eg oracle) .... ? If yes any pointers in...
2,539
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
237
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
140
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
317
