M340 to ControlLogix Comms
Kadesy
Sep 2014
Kalgoorlie
Hi All,
Trying to set up messaging between Schneider M340 (with NOC0401 comms card) and ControlLogix (with 1756-ENBT comms card).
Did a bit of perusing across the inter-webs and found that M340 needs to be set up as the adapter and RSLogix5000 as the scanner as per:
http://www.plctalk.net/qanda/showthread.php?t=77570
Wanting to know if anyone has had experience doing this and can point me in a more detailed direction for set up on both ends. Perhaps a link to a tutorial I have failed to come across?
Any assistance will be welcomed with open arms.
Cheers!
I have a couple of powerpoints-as-pdfs from Schneider on how to do this for Compact- and ControlLogix. The compressed pdfs are still just over 500K, too big to attach. If you PM me with your email address I can email them over.
Awesome,
I managed to run the Spanish copy through google docs translator but the images in that were pretty self explanatory, thanks for that widelto.
But would be still good to have the slides from you robertkjonesjr for technical literature.
Will PM you my email now.
Thanks a lot!
I have a technote from Schneider on making this work, but all the formats are SINT format, whereas our standard in the CLX are DINT/FLOAT. Does...
5,356
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
280
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
169
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
327
I'm using M340 (Schneider Electric) as modbus master. It works fine but if there is a disconnection with the slave, it stops working even after...
443
