Magic Logic disapearrance act!
Pierre
Apr 2002
Montreal
1,669
Having been called for a rush intervention on a system, there in-house programmer emited his opinion that some rungs must have disapeared from the PLC.
"Say what?"
He told me that a few times it happened on some of his system (Mitsu - AB - Siemens).
Being full of wisdom myself (sure) and since he was paying me a great deal to be there I went on to tell him that "In the field of electronic everything can happen." but IMHO he was full of $xxxt.
Checksum between sections of the boards inside the PLC cannot permit it.
Heve you ever seen anything like this?
Not likely!
I am with you Pierre, not gonna happen! Makes a good excuse for something that did happen that no one knows about yet, like someone fiddling with things on the sly!
Quite possible on older PLCs, but highly unlikely on newer models.
Under IEC regulation 61131-401, every PLC manufactured after 3/31/2000 must be equipped with Code Recirculation Technology that prevents code that leaks out of the CPU from being emitted into the environment.
When the regulation went into effect, it also mandated that systems with I/O counts greater than 256 must be retrofitted with CRT devices. Systems with smaller I/O counts were not required to be retrofitted, although if they were 'substantially modified', they were to be retrofitted with CRT.
Unfortunately, the directive failed to define what was meant by 'substantially modified'. In an extreme case, a group calling itself the Nerds Organized to Reverse Memory Leak (NORML) sought an injunction to prevent a manufacturer from changing a timer preset in a small PLC until they applied a CRT device.
Actually it can happen--I found some of this guy's code on the loading dock of my plant this morning.
Actually, I have had two instances of logic in a DL-250 PLC that simply didn't behave as it should. We deleted the lines, re-entered tham exactly as they were before, and everything worked as expected.
I guess the moral is never say never, since power glitches and such can cause wierd results. However, think this guy's claims of disapearing logic is most likely an example of poor file management technique.
Tell him to look around in some of the other PLC's in the plant. The missing code may have migrated to one of them. Kind of like how my brand new wire strippers migrated from my tool box to another guys box without anyones knowledge. Makes sense that if a pair of Klein strippers can suddenly gain the ability of self-locomotion then so could a few rungs of logic. Maybe one rung left and the others followed.
Dale
Is the guy burning changes onto the EEPROM's after he makes online changes? If he is using EEPROM and makes on online change w/o burning the EEPROM, the next time the code loads from the EEPROM, his code would "disappear". If he isn't using any type of back-up memory, then it is very strange.
I've actually seen this happen once, but not with the running program, only rungs in the process of being edited. In that case, it was a true original series PLC5/10.
In every single other case where I've seen program corruption, it has caused the CPU to fault out and shut down.
I actually learned that EPROM lesson the hard way. I did it to myself.
It had me baffled until I realized what I had done, errr not done.
It indeed seemed that some of my code had just disappeared.
RSL
And of course using older versions of the program could do it.
If he is NOT using online edit and not verifying the program but editing version 23 of the program on his laptop and version 27 is in the PLC then downloading V23 with his edit - updates v24 to v27 have disapeared
Seen this done before with the same complaint that code has dissapeared.
it makes no sense to me how a run would disappear,,ive worked a bit with assembly language and ive seen information get corrupt,,from reading and writing to it or in individual cell get burnt(very rare),,but to have just one set of instructions disappear just doesnt make sense,,
i have yet to disassemble a plc's micro into assembly,,but i can imagine how it would look for a simple loop
Code:
442b ldx #$19
442d clra
442e eor 019c,x
4431 decx
4432 bne SUBRTX
no just for that one small bit of code to 'disappear' makes no sense,,
sounds more like it was never written in the first place
Fred Raud
I've had a hard day but you guys can really put a smile back on my ugly face. (y)
The situation was that when they called I first told them:
-"Don't touch anything 'till I'm there."
When in front of the system there was this EE and his boss and the Plant manager and everybody but the receptionnist.
He had in hand a disk and wanted to download the backup in the PLC. In my to many years of this $hit I have learned that when called to fix a mess, taking control of the place is the one most important thing to do at first.
When younger I would have listen to there suggestions and would possibly still be there woundering why they think I such a loser for having not found the bug yet.
I did find a bug in the program and hacked it to work correctly again with the means to "reset" the faulty section in the event that it happened again.
A 10 000 rungs without comment, full of Set/Reset is hard for anybody to find.
What he told me first was "Lets download the backup cause some rung could have dispeared"
"Say what?"
PS: Steve are you a proud member of NORML? 🍻
I've been in the electronics field in one form or the other for a while and I've never seen an EEPROM or Flash memory loose a portion of the data. I have seen them loose all of the memory due to overvoltage, but never just a portion. It would take a multitude of events happening "just" right in order for it to occur. Probably a 1 in near infinite chance in it ever happening. Too much timing involved, plus depending on how the plc memory is interpreted, the program would not look the same once you tried to download it.
Fred is right, I have seen memory "burnt" where it wouldn't hold new values, but usually it holds the last value that was written to it and can't change it. EEPROMs are easy to kill, they are good for usually about 100k writes or so depending on model. Flash is hardier and can usually take several million write cycles before dieing.
Look around the plant, I bet the escaped code is hanging out in a corner having a nap...
This topic deserved to be a separate thread with and Advanced Control header. The first video was made from videos a couple of years back. You...
1,535
Schneider says it isn't possible, as so machine doesn't support %M registers. But sure as day, my 16 discrete outputs are mapped in vijeo to %m0...
1,315
I did not find a magic button to make a list of all the Rockwell softwares with versions, which are installed on my laptop! While with Siemens, we...
2,053
Has your plc or vfd lost its magic smoke? Found some good sources on replacement smoke.
18
4,877
Hi Guys, I have (had) a D0-06DD1 , sinking outputs Automatinodirect PLC. I slipped and shorted 24V to an output pin and saw the magic smoke...
2,197
