TimothyMoulder said:
I've never used Interbus, but I've seen it in the catalogs. Out of curiosity, what went south on you?
TM
Interbus has every good feature that anyone ever dreamed up that you could want for a bus system. Automatic detection of slaves, auto configuration and automatic addressing of IO.
Unfortunately, it turned out like a kiddies first attempt at cooking, i.e. grab all your favorite ingredients, mix them up and taste... yuck!
What we ended up with was a bus that would lock out on any fault and require resetting.
If you reset it, it would re-configure itself. This could be OK, however if one of the nodes was missing or refusing to communicate, it would reconfigure as if those nodes were not supposed to be there.
If you found that you needed to upgrade your equipment, and you wanted to stick your new IO anywhere other than the end of the bus, you will find that the auto configuration will shuffle and re-arrange the hardware IO addresses. You could either go through the code and change all the addresses, or re-configure the IO by hand. But if you re-configure by hand, this will be lost if you press reset again.
These problems can be overcome by using a configuration tool similar to a Profibus setup. This tool costs extra, and when we wanted it, no one would sell it to us (this turned out to be a mis understanding between our supplier of PLC components and the supplier of the configuration software, both thought that the other had exclusive rights in our market).
After introduction to Profibus, I never looked back.
I no longer care what version they are up to, or how much better the catalog says it is. Profibus is good enough for all my needs so far, and that is what I will stick with.
I also like Ethernet, Modbus, Modbus+, ASi and SafetybusP.
I have used the cut down version of interbus that Modicon supplies with its momentums with great success.
I have nothing against Devicenet, only I have never had the opportunity to use it.
I refuse to use Interbus again.
