Maintain Multiple Wonderware Stations
AMarks95
Jul 2018
South Dakota
224
Working for an SI. Most clients are Factory Talk ME or SE. Not done much with Wonderware. I've been tasked with adding/updating the overview system with a new sub-system.
I've dealt with duplicate SE stations and copying gfx, par, etc. files between the stations. Not sure how to best go about maintaining multiple Wonderware stations.
Any tips/suggestions?
The answer really depends on the extent of your use case.
Wonderware has a 'NAD' (Network Application Development) feature that can monitor a central storage location on a server and automatically detect and pull changes. You can fire up a standalone Intouch node, enable NAD, and point it at your project files on the server.
If you need more (e.g. centralized user management / symbol development, etc), consider managed application development using an ArchestrA galaxy.
Agreed. When using a Galaxy you install basic bootstrap on the HMI node and can deploy the HMI app from your dev node with a few clicks.
Make sure you know the tag count and the license limitation.
what is the license good for and i would count the tag additions before you start. Make a back up copy and put it in a safe place for insurance.
james
Hi all, I am using a logo 12/24 to start a generator when power fails. Initially logo is power from a 24v supply, then when the power fails it...
2,784
Good Morning , I think I have upper management convinced to begin replacing our SLC 500 PLC's . It is incredible the increase in price on SLC...
2,074
Using BootP Version 3.00.00. What do you need to do to maintain the IP Address when a panel is powered down ? Thanks.
2,084
I'm working on an application using FTView Studio SE, FT Trans. Mgr., and a SQL database with custom tables/stored procedures. I need to provide...
6,426
Dear All, How can we maintain a room temperature at 10 deg C.The Chiller system having 5 nos of 22.5kw compressors and 2 nos of 18.5 kw...
3,817
