recabite
Greetings all
Every now and then i get a MNRE (Major Non Recoverable Error) with our L61 Cpu's usually when they get powered down which dumps the program.
What i want to do till i work out why this is happening is clear the fault and restore the program from a Compact Flash. How do i do this? Any info or links to older post will be gratly appreciated. Also will the CPU need to be powered down and restared or is there a way just to clear the fault and reload program. Personally i like the from run to program then back to run method.
