Make A copy of FactoryTalk SE Network distributed
BeepBob
Jan 2023
Oakland, CA
107
Hello,
I am trying to make a copy of a FactoryTalk SE Network Distributed application.
I want to make modification but do not want to work on the original project. I
can do it easily in Application Manager for Machine Edition. But it seems like I
can't just do the same for SE Network distributed app.
Can someone show me a way to made a copy of a SE Network distributed app?
Can I just make an archive, name it something else, then restore it?
Look under Rockwell Software --> FactoryTalk View --> Tools --> FactoryTalk View SE Application Manager
Stu....
I'm going from memory on this, but I believe they do not have a "copy" function for SE network applications like they do for ME applications. Instead you have to perform a backup and then do a restore. You give it a new name as part of the restore. Renaming the backup file won't do anything.
OG
OG
Awesome, thank you OG, just as you described.
I have a FactoryTalk ME application with some global objects for diagnostics of 1769 and 1719 IO modules that don't work. They were developed by...
1,907
Running redundancy for OPC topics (RSLinx Pro is the data server)...switched from primary to secondary so that I could add topics to the primary...
1,483
I have an Allen Bradley Factory Talk touch program that currently works. I want to use the same program for another machine with a new processor...
2,819
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
73
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
135
