Managing Tech Support cases
plc noob
Oct 2007
atlanta , georgia
258
Does anyone use or know of a free or lowcost solution for managing tech support cases.
We use tech support quite alot.Primarily AB and they give you a case number.We typically try to manage this in a word file and keep the status updated.But with multiple people using the sheet and many cases it gets cumbersome to manage and keep up to date
Anyone have a better idea?
Its not that hard really. Probably wouldnt take much more than a couple of hours to setup and start entering data. No time like the present, plus, you can't beat the cost!
I dont know if this will help or not and not even sure if the book I have is current. But anyway when I started doing my first and so far only SCADA system one of the things I invested in is a DUMMIES GUIDE TO SQL. It is quite helpful. But more to the point in the version of the book I have, which by the way I purchased off of ebay, there is a simple section on doing a DB for orders. And with a little modification to the field names I am sure it would probably work for keeping track of you case numbers. I would highly recommend the book and if the one you get does not have the section in it about this let me know and I will check to make sure it does not constitute any violations and then I will if possible post the sample given in the book.
I was primarily looking for something turn key because i have never done any DB work.But this may be a good time to give it a try
Since we don't have any inkling of how your company is set up, or what is available to you, all I can offer is what we use.
I use a Sharepoint site to keep this type of data - available to everyone with access, and can be managed between users.
Hi! I would like to ask you, how are you managing the alarms from Motion Control that has to be displayed in HMI. If we have two drives (one FC...
1,803
We manufacture machines with lots of variable parameter set points, mostly DINT's but some BOOL. The issue we have is if a software/project...
2,200
If you work for or own a company with multiple automation engineers, how do you manage keeping your files in sync? I'm using a dropbox to sync...
1,596
Is it me, or is the number of necessary AOP's needing to download getting out of hand for RS5K products? I just had to do a fresh VM install of...
2,204
Has anyone had any experience communicating with a fanuc robot using SAP? I've got a customer that would like to send program/part selections...
1,717
