mahone Member M Join Date Apr 2014 Location Singapore Posts 62 May 21, 2020 #1 i'm runnning a old citect project with version 5.3. it is using MBPLUS driver, i get this warning msg MBPLUS not initialised you want to shutdown runtime? anyone know what is this? thanks
sigmadelta Member S Join Date Apr 2016 Location From Canada - Living in Bulgaria Posts 2,010 May 22, 2020 #2 Maybe this document will help you. You should enable the kernel in Citect.INI or in the Computer Setup Wizard, so you can access the diagnostics of Citect. https://ufile.io/mernq8iw
