Mettler Toledo Scale
freepat
Feb 2007
MONTREAL
Hi, I need to communicate with a Mettler Toledo Scale with ALlen_bradley Rio Option. I using a 1747-Sn, my plc is a SLC503, rslogix 500 7.10. It's just for weight display
Anyone can help me with a sample or a tips
thanks
thanks
Done it many times, pretty straight forward and reliable. What do you need to know?
Ian
Never did it with a SLC, but have used it with many 5's. It's been awhile, but if I remember correctly the scale is 1/4 rack, with two input words, and two output words. You need to acquire the manual on the scale rio module, one of the input words is the weight, and the other one contains status bits. The output word can be manipulated at the bit level to reset, tare etc....
No BTW or BTR required, the data will be in the I/O image table, you just need to manual mentioned above to decipher what's located where. Unless Metler-Toledo has changed the way they do things, you will have to get the manual from you local rep. you cannot download it, and it's not on the standard CD that ships with the scale. Which scale module are you interfacing with, the Jaguar?
Configure Toledo as 1/4 in 1747-SN G data area
weight is first I/O word
status is second
documentation gives status of bits
user program usuage
Sort of correct. The weight can overflow into the second word. It can be up to a 21-bit signed value if you select the EXT format (extended). There are some logic examples on the Mettler documentation CD that gives you some ideas on how to parse this. In my case I needed this to get the additional range and resolution.
Darren
Darren
This must be new to the Panther , or are you referring to the Jaguar?
Which parameter is this
Ian
I was fairly certain that this was available on the Panther as well as the Jag Extreme, but I could be mistaken. It has been awhile since I have used the Panther.
Darren
Can you give more details, post your SN configuration?
What is the RIO setup R/G/S?
Do you currently have other RIO?
If so do they work?
What does the status LED of the scanner look like?
Are you using true "blue hose", what baud rate?
and so on.
The more details you can post, the less questions we will have to ask.
Ok, I got It. My 1747-Sn config: Logicial Rack 0, Group 0, 1/4 rack, 57 kbaute, 125 ohms
IND560 config; Node 0, file type integer,
Very sample. Your have a message on IND560 when Sn and Scale is ok;;;;; PLC is Online...
thank you
Good Morning , I am working on a system that will distribute oil to a mixer in pounds , using a Mettler-Toledo scale , to check the loss of...
1,629
I’m having a little problem with the finishing touches on integrating a Mettler Toledo scale. I have a WMS204, setup with an Ethernet/IP module...
4,478
Hi, I had a look on the internet about coding SAG105 weighting scale, but haven't managed to find a code that I can understand. I would really...
3,524
How to do that can any one give me the how to write instructions example
840
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,204
