Micro Motion mass flow meter programming
phuz
Jun 2008
Mohnton, PA
1,044
I was trying to configure a Micro Motion gas flow meter today. When plugged in with HART, it shows itself as "1700 Analog Mass Meter". We want the 4-20mA output to be units of SCFM, but when trying to send it, it fails writing the value. It is only allowing mass flow (g/s) or volume flow (L/min). Is it possible the sensor is incorrect or is there something we could be doing wrong in terms of configuration?
We only wanted to set the units and a range of 0-500 scfm, well within the allowed min/max.
G/s or L/minare liquid volumetric units, not gas units.
Somewhere you've got to tell the flowmeter that it is a gas flowmeter, or maybe it isn't.
You will probably need to get a copy of ProLink which is their configuration software for their sensors. This will allow you to setup their scaling, unit types and limits.
hello, i am using compact logix L16ER PLC and emerson Micro motion 5700 MFM. i used TOTALIZER block in studio 5000 to calculate transferred...
2,550
Hello all, I have a Micro Motion Ethernet I/P module connected to a compact logix And Im confused about what the inputs represent in the manual it...
2,203
Hi all, My project require get data from Micro motion 2700 transmitters and Honeywell CUI 880 primer with 2 MVI69-MCM cards (using Modbus RTU)...
2,015
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
105
