Micro810 12QWB smart relay..how to enable 4 AI ?
moh252
Nov 2014
baghdad
Hello all
This is my first time I post here, I am new in PLCtalk
It is interesting small size, 8-IN, 4-OUT, LCD..
I have 12qwb and read in the manual it has 4 AI.
But I don't know how to activate these 4 AI Channels..
additionally , are these 4 IA the first 4 ports or the second 4 ports?
by the way CCW is the software used to program this micro plc..
have any one used this??
Thank you for your reply and help.
I understood that if the voltage on these ports is between 0-10v then it will be regarded as AI input, or it was from 12-24v then it will be regarded as DI.
Is this understood is correct?
No additional procedure(configuration, enabling) required?
Hi, I am currently using a micro810 12qwb to turn on a relay. The relay is to control a motor. My question is how to wire the output of the plc...
2,666
In this project I wanted two pumps to alternate between lead and lag. The controller is a Micro810. I'm using a counter to dictate whether pump 1...
1,124
Hi, I'm experienced in Studio 5000 / ControlLogix but have a small project to do in a Micro810 with CCW and something is driving me nuts. I want...
4,075
Hello everyone I'm working on a project where i have to use the pid instruction (ipidcontroller) in my AB micro810 plc to control the water level...
2,606
