Micro810
Kgaraffa
Aug 2017
Jackson Ohio
I am switching from a Pico controller to a Micro810 plant wide, is there a way to transfer the programs from Pico to the Micro810 without having to write a new program for each application?
I would say no... page 5
This document is intended for users of Pico controllers who are converting to a
Micro810, Micro820, or Micro830 controller, and who are familiar with the
PicoSoft software. Knowledge of programming in ladder language is expected to
be able to program Micro800 systems effectively.
I think what kgaraffa is looking for is way to automatically convert the "pico controller" program into an "Micro810(CCW)" program. That document explains what is needed for the programmer to write a program for the Micro810 that would do the same thing that the Pico controller is doing.
I have looked over that document and I see no way to just press a couple of buttons and the Pico controller program be converted to a Micro810.
Personally, I see no benefit to swapping a Pico for a Micro810. At least go with the Micr820 and get the Ethernet connectivity out of it. Especially since you have a bunch of them.
Making the new code for them would be easy then.
My thoughts!
personally, i see no benefit to swapping a pico for a micro810. At least go with the micr820 and get the ethernet connectivity out of it. Especially since you have a bunch of them.
My thoughts!
+1
Buy the time you add the adapter and cable and you lose a few of them than its cheaper with the 820 :)
In this project I wanted two pumps to alternate between lead and lag. The controller is a Micro810. I'm using a counter to dictate whether pump 1...
1,108
Hi, I'm experienced in Studio 5000 / ControlLogix but have a small project to do in a Micro810 with CCW and something is driving me nuts. I want...
4,042
Hello everyone I'm working on a project where i have to use the pid instruction (ipidcontroller) in my AB micro810 plc to control the water level...
2,592
Hi all, I've recently been tasked with programming an AB Micro810 to automate a light system. I'm fairly new to PLCs and have only been using CCW...
2,184
