Micro820 Data logging to SD Card - Folder Structure?
jakeparsons03
Jun 2017
Indiana
78
Do I have to create a folder structure within the SD Card in order for data logging to begin?
I have a Micro820 that I am setting up as a data logger. I have a SDHC 32gig sd card in the sd card slot and the program is saying that there is no sd card there. I am wondering if I have to set up a folder structure in order for it to recognize that there is an sd card there. It is currently formatted. This is a brand new install
I saw in the manual that the datalogging folder gets created under the project folder. Do I have to create the project folder in order for it to recognize the SD card or does it do that on its own?
Yeah. I had a SanDisk SDHC Fat32 micro SD card which the manual said would work but Rockwell just told me to get their 60 dollar 2gb sd card. I ended up just going a completely different path.
Hi Gents,
I have a Micro850 PLC and a banner iVu Gen2 camera.
I need to communicate between the two devices.
I have been trying to use the MSG cip instruction but have had no joy so far.
I have also attempted to communicate between my compactlogix PLC and Micro850, using the MSG instruction and that works.
Any help would be appreciated.
Thanks in advance.
Hi Gents,
I would contact Banner and have them help, odds are they have papers wrote up and how to set them up
Hi everyone, I have a small project where I need to use plc to get sensor data and log them to an sql server locally or remote. I have found...
2,820
I am trying to transfer some data from a SLC5/05 to a Micro820 (122 bits and 4 integers), and I cannot find any documentation that shows how I...
2,076
I have the HMI setup as shown in the picture. Then from my PLC and from the handy Baseblock ComTest Pro program I get a illegal data address. "...
4,432
Hi Guys I have completed a couple of applications with the Micro820 from AB so I thought I would use one for an automated test system. I have a...
7,143
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
833
