Microcomputing (siemens software)
reganas
Sep 2003
Hi all,
Sorry if you find this post more than one time, I get a mistake ....
Could someone help me about the use of Microcomputing.
In fact I need to use it with the PPI protocol with 1 or 4 CPUs.
In the siemens documentation, they always says that it is better to use it with CP card.
What is about the use without it ?
If I need to communicate with many CPUs how does it working ?
Could I use 4 COM ports with a CPU on each of one ?
Does Microcomputing allow me to have communication to each CPU accross each PC port ?
Thank you for your help
If you have any other good information, I am well getting it ...
Patrick
PS : Have a nice end of year ...
reganas said:
Hi all,
A card from Siemens that communicates using PPI would be the easiest.
What documentation? Do you have the specification?
Writing your own PPI protocol would not be easy. Even if you had the specification. It looks to be harder than DF1. If you don't have the specification then it would be very difficult to reverse engineer. Buying the card would be cheaper.
The physical layer is a RS-485 line that has multi drop capabilities.
There are masters that only talk when they have the token and there are slaves that respond to the master.
That shouldn't be necessary with a RS-485 line.
Yes, but you would still need the specification and you would need to properly implement the specification. This could be done from one Siemens card.
Microcomputing
Thank you for your answer...
But I want only use microcomputing.
Then, I have read the microcomputing documentation and specification.
I didn't found any informations about the use of microcomputing unlimited in this case for working with more than one CPU.
At this time, there isn't any good help with the siemens support line.
Then I post this question here.
I had try to make reverse engeenering as you said, but I didn't have the time to do it (and Siemens didn't sale or give the PPI Protocol specifications). So, I have to use Microcomputing.
The only bad reason to unused it, is the PPI speed (9600bps).
In fact, I use the biggest S7-200 available, and there is just 30 programming bytes available too. Then I can't do something else.
So, do you have already use microcomputing with more than 1 CPU and without additional CP Card ?
If so, How is it working ?
Thanks a lot
Patrick
Unlimited Micro Computing will work with more than 1 CPU, where "Limited" will work with 1. The packages run $195 vs $299 for the Unlimited version. There is little Siemens help, it was kind of an Orphan software. The reason for wanting you to use the CP5613 card, was throughput speed and Serial Port Limitataions. If you are trying to feed a bunch of data through the serial port to more than one CPU, it won't work well. You are having to send it through the PPI adapter cable and it isn't designed for it. The CP5613 card has it's oun CPU on it and talks directly to the PPI network between CPU's and can run 187.5 KB instead of 9.6 or 19.2 K
Microcomputing
Thank you for your very technical and good reponse
You have well helping me
I hope that I can help you later ....
hello guys, can you please be very kind and tel me where I can buy a license for microcomputing , siemens web site dont seem to have it!! or...
2,133
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
297
105
160
