Micrologix 1100 1762-IF2OF2 module issues
Blue92
Sep 2019
N/A
27
So I got my ML1100 up and running last night, and tonight Im trying to connect an analog in/out module 1762-IF2OF2. The problem is that the green power on light on the module is not coming on consistently with the PLC. I can plug/unplug the PLC 10 times, and the module will only come on maybe 2 times out of the 10. This is causing a fault code saying that the PLC isnt recognizing the module that Ive configured in the logic. Is this a bad expansion module? I have +5v, -5v, and +24v coming from the pins on the ML1100 expansion plug so I know its sending power to the module. It was a used ebay purchase so Im not surprised if it is a bad module, but its rather disapointing.
Do you have another 1100 or analog card that you can swap? this may tell you one or the other is the issue, I would agree that is sounds like the card, one thing I would check is the dip switches... make sure they are on the volt or current setting and not half way, that may cause a issue but just a WAG
There are known issues with firmware older than FRN 4 when using certain analog expansion cards. What is the FRN (firmware revision number) of the Micrologix?
With the ML1100 being a Legacy product, this is something of an academic discussion. I have an ML1100 with two expansion modules - 1762-IF2OF2...
867
Hello! I am new in this field, and I have a task to wire inputs/outputs to MicroLogix 1100 1763-L16BWA Ser A Rev C with its Expansion Unit...
1,662
Hello there, Using the Micrologix 1100 with the 1762-IT4 Thermocouple/mV input module, is it possible to have the ladder logic program update the...
7,916
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
