MicroLogix 1100 as remote
gustavo_dias
Aug 2016
Minas Gerais
76
My client has a MicroLogix 1100 with 4 expansion modules and want to expand more their system. I'm studying some solutions like change the 1100 cpu by 1400, or use another 1100 CPU like remote.
Could I use a MicroLogix 1100 as remote?
You can easily set up the Micrologix to send/receive information via Ethernet. But you would need to use the MSG instruction (on one end) and map the data to files yourself. You won't be able to treat it like a Remote IO in the IO Config in something like a Control or Compact Logix system.
Switching to a ML1400 from a ML1100 is relatively painless since the 1100 and 1400 use the same programming software and hardware IO, and with a quick processor change, can use the same program with no logic or syntax changes.
i am looking into changing my current device net i/o to the Phoenix contact ethernet IP bus coupler. Any suggestion on making the change? Is it...
3,530
I have been told you cannot control any remote I/O using the Ethernet port on a MicroLogix 1100. Is this true? Does anyone knows which...
9,413
Hi I want to get remote access to a Micrologix 1100 using the ethernet port CH1 as I am already using CH0 for a RS232 device. I can't get...
5,599
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
151
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
550
