Alternate 1 quick method, requires a Mac OS X system:
If you have a Mac OS X on the network (not likely, I know):
- start a terminal window
- Enter the command
You should see a list of IP addresses paired with MAC addresses e.g.
Code:
? (192.168.1.112) at xx:yy:zz:aa:bb:cc on en1 ifscope [ethernet]
The MAC address (xx:yy:zz:aa:bb:cc) of the MicroLogix 1100 (ML1100) should be somewhere on PLC body and/or label; pair that with the IP address (192.168.1.112 above) on the same line in the [arp -a] output.
Alternate 2, requires a DHCP server with a web server, and a PC with a web browser on the same network:
If the ML1100 is getting its IP address via DHCP, you might be able to query the DHCP server; most routers that supply the DHCP service have built-in web servers
Alternate 3, requires a packet sniffer e.g. WireShark:
Filter for messages from the MAC address of the ML100; it will take a little decoding but the IP will be in an ARP packet that the ML1100 sends out every two minutes.
Alternate 4:
https://www.advanced-ip-scanner.com/
I make no warranties about whether that is a valid product or not; I loaded it on my Win10 VM so I don't care as the VM can be replaced.
TL;DR
Alternate 1 (Mac OS X and [arp -a]) is only anecdotal at this point, so it would be great if someone else could test this.
The MicroLogix 1100 sends out an Address Resolution Protocol-related (ARP) packet every two minutes, and OS X apparently listens and puts those in its ARP table. Unfortunately Window sdoes not do the same (or maybe it does, and my Window 10 VM guest on a Linux host with a bridged adapter does not).
I found these using [tcpdump] on my Linux box, and noticed the ARP result on my Mac; I suppose a Windows packet sniffer could do the same (WireShark?) i.e. leave it running and filter for packets by the MAC address of the ML 100; you should see one after at most a couple of minutes.
Code:
# tcpdump -i wlo1 -e -U -XX ether host xx:yy:zz:aa:bb:cc
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on wlo1, link-type EN10MB (Ethernet), capture size 262144 bytes
07:57:09.757510 xx:yy:zz:aa:bb:cc (oui Unknown) > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 192.168.1.112 tell 192.168.1.112, length 46
0x0000: ffff ffff ffff xxyy zzaa bbcc ddee ffgg ........s.r.....
0x0010: hhii jjkk llmm xxyy zzaa bbcc c0a8 0170 ........s.r....p
0x0020: 0000 0000 0000 c0a8 0170 0000 0000 0000 .........p......
0x0030: 0000 0000 0000 0000 0000 0000 ............
that [c0a8 0170] at either 0x001c or 0x0026 in the -vv dump is the IP address: c0.a8.01.70 = 192.168.1.112
N.B. MAC is not the same as Mac above.
