micrologix 1100 martes DF and 4 micro 1100 DF slave
renatopa
Jan 2012
LIma
please, i do a project to programing a this system, i use the message block, because the slave are 8km between the master and slave.
i send analog data of level transmitter, and pressure transmitter to see in th intouch 10.
I have problem to use this block (message), i want to listen some problems that you had went you implement a same project.
i am sorry with my poor english!!!!
If you wish to have assistance from this Forum, you must describe in detail the configuration of your system and the configuration of the MSG instructions.
If you post your *.RSS program files, Forum members may be willing to examine them for you.
Include descriptions of the physical wiring and signal converters between your Master and Slave devices. Are you using fiber optics, or wireless, or modems ?
good, the proyect is to control pumps transmitter, level transmitte. have a modul of analog signal for the transmitter 4-20ma. the informacion of this slave travel trought radio moden because the distance is 8 km between each slave to the master.
Also this configuration is same to the 3 tanks.
the master have the radio moden, and this have the program to start and turn off the pumps, and the variable to have in the slaves, show in the scada intouch 10. in ethernet comunication.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
150
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
549
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
201
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,201
I have a MicroLogix 1100 and it's capable of ac or dc output voltages. What I don't know is how I'm supposed to tell the 1100 to use dc for the...
1,424
