Micrologix 1400 and PanelView Plus 600 using RSLogix 500 and FTView
Christine1914
Apr 2011
Manila
49
Hi Guys,
Good day!
I hope you can still extend your help to me again.
I have this new project, but my problem is I cannot open the PLC program given to me by my client. I am encountering two different message box when I am attempting to open the file (screenshots are provided).
Is there anything that I need to configure first before I can open the PLC program? Password or something?
Hope you can help me again with this one as soon as possible.
Thanks in advance.
What revision of RSLogix 500 are you using ? Could the program have been written for a newer controller than your software supports ?
If you can ZIP and post the *.RSS file, other members might be able to check it with current software. If you cannot post it publicly, send me a PM and I'll take a look at it.
The other possibility is that the file really is corrupted, as the error message suggests.
I've seen the same error messages when trying to open a project in RSLogix 500 pro that was developed in RSLogix Micro, and vice versa. Even though they are both saved as .RSS files, for some reason the versions are incompatible. I don't know if this has anything to do with your situation Christine, but I mention it because the error msgs looked so familiar.
I always get the first error message "Unexpected file format" if I try to open a RSLogix500 program that was saved with a newer version of the software than I am using.
Hello Friends I have a PanelView 800 (2711R-T7T) connected with a Micrologix1400 (1766-L32BWA) and an output module (1762-OW16) I have done some...
3,757
Dear All. I have arranged an upgrade software to convert my micrologix 1000 program for ML1400. Now I am having problem communicating my ML1400...
3,146
Hi there, I seem to be having some issues interfacing a Mircologix 1400 and a Panelview plus 1000. All communication is done over ethernet...
2,384
I've run into a problem with my Panelview C600 and modbus comms to a Micrologix 1400. I can set up a numerical entry on the screen, and it works...
3,256
I'm working with a Micrologix 1400 and a Panelview C600. I can get them working together fine over ethernet, but am having trouble getting the...
2,962
