Micrologix 1400 Custom webpages
aw4lly
Dec 2010
Home
Hi everyone,
I'm working on the Micrologix 1400 and trying to make some custom webpages for a customer.
I can display the datatables with a title fine but in the documentation for the PLC it seems to show the data which has been extracted from the table. (Page 37 of here: http://samplecode.rockwellautomation.com/idc/groups/literature/documents/um/1766-um002_-en-p.pdf)
I am also unsure of how to display any normal text here, if I just type text into the webpage I make, it just doesn't show up on the page.
Any help or sample code would be amazing, I've attached the sample code for what I've got so far.
Cheers,
A
Hi everyone,
Cheers,
A
Just went threw the same Issue Here is what worked for me.
Hey Randy,
I was just wondering if you would be able to attach a screenshot of the output at all since my ML1400 is being installed on site today? Thanks for your help.
Cheers,
A
If your talking about the web page I dont have access anymore.
But this is where I had posted my Question.
http://www.plctalk.net/qanda/showthread.php?t=59702
Oh ok, I was ok getting the text in the comment block of the table, I just want to be able to have text which is NOT in the table, I want to write up a description of how everything should be changed and ranges etc. Thanks anyway though.
Does anyone have any ideas about how to get text which is NOT just in the datatables?
I think to do that you will have to custom write the code in html.
I tried doing that it just became time consuming.
There is some HTML code generators out on the web.
Here is what I started.
The text In this could have been as needed.
This worked perfectly, thanks heaps for that!
Cheers,
A
80
122
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
236
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
338
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
702
