Micrologix 1400 digital input as a counter
marcinski
Jan 2014
Chicagoland
32
Hi all
I have a Micrologix 1400 1766-L32BXB and I want to use one input as a pulse counter from flow meter. I don't want to use HSC to save on input points (for now)
Did anyone used it that way, and what is max pulse that digital input can keep up with without losing any pulses?
That can be done. The max pulse rate will be 2 times the scan rate of the CPU. Unless that processor does interrupts on its inputs, then you can get whatever the fastest interrupt is.
34
97
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
224
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
305
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
651
