MicroLogix 1400 L32-BXBA
Christoph
Sep 2003
Indiana
345
I have a project using the Micrologix 1400 L32BXBA.
i found in the manual which outputs are the Fast outputs. I know there are
a few Fast inputs as well, But I do not find a table like I did for the outputs.
Anyone know which ones are the Fast inputs or where I can find that info?
Thanks!
are fast inputs a thing? I thought that fast outputs were from those safety PLCs that could hit outputs at a much lower latency than other normal PLCs, but I didn't know that inputs could work the same way.
Yes, fast inputs are a thing.
For instance, with a 5069-IB16F input module, you can set up the 1st 8 inputs (2 groups of 4) as 30KHz counters. It works really well with flow meters. Also, a heck of a lot cheaper than an HSC module.
32
95
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
223
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
304
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
651
