Micrologix 1400 LCD
alphav
Supporting Member
Sep 2007
Ontario
35
Hello everyone,
I have two questions regarding using the LCD in "User Display" mode.
1. Is it possible to monitor in the program if the cursor button is pressed UP, DOWN, LEFT, or RIGHT?
2. If I set the LCD Command "L4 Source A" as an Integer and "Display with Inputs" = YES, the LCD shows "= 00005", if the Integer=5.
Are there anyway I can show only one(1) digit without the leading zero's as "= 5" ?
Thanks,
My project uses a MicroLogix 1400. First time I’ve used the 1400; used the 1500 for a few projects. I have 1.5 years’ experience programming...
6,849
60
118
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
234
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
314
