Micrologix 1400 loses coms intermittently
stu
Aug 2005
England
785
Hi guys
I have an intermittent issue with a micrologix 1400 which connects to a pvp 700 via Ethernet loses coms
I’ve been told by our shift engineers that our liquid system runs ok for weeks and then loses coms ? The only way they get it working again is unplug the Ethernet from the plcand plug back in and then it works ok until the next time ?
No fault light , or codes??
Can we trap the fault or is there anything Pacific to look for ?
Thanks stu
Is there an Ethernet switch involved, or is it a point to point cable?
If there is a switch, I'd try swapping it. I've seen many such intermittent comm failures over the years caused by a failing switch.
Is this a new problem? Definitely change the switch as stu said, and maybe the cables. If the Ethernet cables run along something with high voltage or high frequency, then the Ethernet cables should be double shielded (foil and braided).
54
109
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
229
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
311
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
673
