Micrologix 1400 & Mitsubishi D700-SC
johnmam
Dec 2017
Athens
Hello everyone,
i want to connect these 3 devices:
1. Micrologix 1400
2. Mitsubishi Inverter D700-SC
3. Simple laptop or PC
So, my VFD only supports Modbus/RTU according to the manual (RS485).
I want to connect all 3 of them through ethernet network.
I also have a Digi One IAP HAZ for the Ethernet- Modbus/RTU conversion.
Something similar to this:
aaand it's not working. Do i need a second Digi or it should be working just like this?
Do you need to upload my channel configuration and my ladder code for the MSG?
My second plan if this doesn't work out is to connect
1. The RS485 of VFD to RS232 port of Micrologix through a RS232 to RS485 converter
2. Micrologix with an ethernet cable with my laptop.
And it's not working either. I am a student, so i don't know exactly which steps i should take to ckeck where the problem is.
Thank you and sorry for my bad english.
i want to communicate micrologix 1400 plc to mitsubishi gs2107 hmi. what configuration shoud i do ?
1,071
I am new to this. I have a customer wanting to use a MicroLogix 1400 to control a Mitsubishi A8NEIP-2P. All I can find on the Mitsubishi site is...
2,242
So, here's my hardware: Micrologix 1400 controller Mitsubishi E740 Drive I'm communicating via the 1763-NC01 out of Channel 0 on the Micrologix...
4,929
My main question is what hardware do I need to make the connections. Is a 1761-NET-AIC module required? I'm going to use channel 2 (the 9-pin...
2,859
60
