Micrologix 1400 PTO Jog Speed Blend
BillJW
Jun 2012
Oregon
I currently use a Jog Continuous at 5000hz successfully. My application requires a two speed blended jog now. I need to start the jog at a frequency of 2000Hz, then on the fly increase it to 8000Hz. I have tried moving (MOV) a second Hz value into PTO:0.JF but the second speed will not take effect until I stop issuing the Jog Continuous JC signal and then re-issue.
Thank you for your comments.
MicroLogix 1400 Stepper
Hello
In the first post motion is in the form of a Jog at 5000hz. A blended is a series of relative Moves. Try using the Copy File for each blend.
But keep in mind that the next move cannot have the same speed and there has to be sufficient number of steps to reach the speed, accel & decal rate.
Hope This Helps
Tom
Hi, I can't seem to find a thread on this, so I'm starting one. I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need...
1,689
Hello Everyone, I have a new project that I will be working on over the holiday break and have never done a stepper before I am using a...
2,886
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
94
127
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
244
