micrologix 1400/sureservo sva-2100 modbus rtu
Would
Sep 2013
Arkansas
Hello, I have a project at work that requires me to communicate to a micrologix 1400 via modbus to a sureservo sva-2100. The connection will be modbus rtu via a serial port on the micrologix. I have had zero experience setting this up. Can someone give me a few steps to start this out? I am required to get speed readings from motors and then be able to change speed on the fly via modbus.. I know I need to set up the modbus on channel 0, and also set up a MSG in RSLogix but from there I do not know what to do.. I am not exactly sure how to set up the MSG function with this. Any help is appreciated.
41
101
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
225
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
308
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
656
