micrologix 1400 user power
Aug 2021
tecumseh mi
52
Howdy Everyone,
I am doing a project with micrologix 1400 1762-L32BWA, where we talk thru message bits one direction and talk thru the discrete I/O the other way to get two PLC to talk. Long story why we cant just get the two to talk, but this was the cheapest fastest route. THey were all ordered cause it is on 5 machines. THen i realized all that is available is 120v I/O on the discrete side. i know i can use 120v on the outputs of the micrologix 1400. I will have to use 24v on the input side. My question is the user power that is in the top left corner of the PLC. i swear someone once told me there is a reason not to use it, or restrictions, but i cannot remember for the life of me. All the other machines we have just use external 24v so it isn't an issue. All I need the 24 V for is when the outputs of the 120v plc close the relay it gives me 2 different inputs on the micrologix, so it isn't pulling alot. Just wanted to see if anyone knew of restrictions before i started trying to use those. thank you.
I am getting the following error: The program has exceeded the memory limit of 10k user data words. I am trying to store some string values in...
6,728
41
101
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
225
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
308
